Unit Consistency
In Radioss, data for any unit system can be provided, but it is very important to keep the unit consistency. If your model did not keep unit consistency, this will lead to the incorrect results (unexpected behavior) or sometimes may lead to an error in the calculation.
Basic Units
  SI     CGS Hydro US Japanese
Length m mm mm cm cm in mm
Mass kg Mg(Ton) kg g g lb kg
Time s s ms s µs s ms
Plane angle rad rad rad rad rad rad rad
Temperature K K K K K K K
Frequency Hz Hz Hz Hz Hz Hz Hz
Gravity 9.81 9.81E+03 9.81E-03 9.81E+02 9.81E-10 386 9.81E-03
SI Unit Example
SI Unit Example
Length
[ m ]
Mass
[ kg ]
Time
[ s ]
Plane angle
[ rad ]
Temperature
[ K ]
Frequency
[Hz]
Rotational velocity
[ rad s ]
Area
[ m 2 ]
Volume
[ m 3 ]
Moment of area (inertia)
[ m 4 ]
Consumption
[ m 2 ]
Speed
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
Acceleration
[ m s 2 ]
Tension
[ m s 2 ]
Lineic mass
[ kg m ]
Surface mass
[ kg m 2 ]
Volume mass
[ kg m 3 ]
Mass flow
[ kg s ]
Volume flow
[ m 3 s ]
Quantity of movement
[ kg⋅m s ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiaacUgacaGGNbGaeyyXICTaaiyBaaqaaiaacohaaaaacaGL BbGaayzxaaaaaa@3E05@
Kinetic moment
Moment of inertial (l)
[ kg ⋅ m 2 ]
Moment of force
[ N ⋅ m ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaaci GGobGaeyyXICTaciyBaaGaay5waiaaw2faaaaa@3BFA@
Force
[ N ]
Linear force
[ N m ]
Stiffness
[ N m ]
Rotational stiffness
[ N • m rad ]
Rotational damping
[ N • m • s rad ]
Torsion damping
[ kg⋅ m 2 s⋅rad ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiaacUgacaGGNbGaeyyXICTaaiyBamaaCaaaleqabaGaaiOm aaaaaOqaaiaacohacqGHflY1caGGYbGaaiyyaiaacsgaaaaacaGLBb Gaayzxaaaaaa@43FF@
Viscous damping
[ kg s ]
Damping for bending
[ N • s m ]
Quadratic bulk viscosity
[ P a λ ⋅s ]
Dynamic viscosity
[ Pa⋅s ]
Kinematic viscosity
[ m 2 s ]
Density
[ kg m 3 ]
Power
[ W ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaaci GGxbaacaGLBbGaayzxaaaaaa@38C6@
Energy
[ J ]
Enthalpy
[ J ]
Entpory
[ J K ]
Strain rate
[ 1 s ]
Permeability
[ rad s ]
Time relaxation
[ s ]
Thermal expansion
[ W m 2 ⋅K ]
Thermal conductivity
[ K o W ]
Thermal resistance
[ W m 2 ⋅K ]
Specific heat (Cp, Cv)
[ kg s 2 ⋅m⋅K ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiaacUgacaGGNbaabaGaai4CamaaCaaaleqabaGaaiOmaaaa kiabgwSixlaac2gacqGHflY1caGGlbaaaaGaay5waiaaw2faaaaa@420B@
Specific heat capacity (Cp)
[ J m 3 ⋅ K ]
Verify Consistency
Use basic units Mass, Length, or Time so you can get all other units you need.
Force=Mass⋅Acceleration= Mass⋅Length Tim e 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiaad+ gacaWGYbGaam4yaiaadwgacqGH9aqpcaWGnbGaamyyaiaadohacaWG ZbGaeyyXICTaamyqaiaadogacaWGJbGaamyzaiaadYgacaWGLbGaam OCaiaadggacaWG0bGaamyAaiaad+gacaWGUbGaeyypa0ZaaSaaaeaa caWGnbGaamyyaiaadohacaWGZbGaeyyXICTaamitaiaadwgacaWGUb Gaam4zaiaadshacaWGObaabaGaamivaiaadMgacaWGTbGaamyzamaa CaaaleqabaGaaGOmaaaaaaaaaa@5D91@
Pressure= Force Area = Mass Length⋅Tim e 2 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuaiaadk hacaWGLbGaam4CaiaadohacaWG1bGaamOCaiaadwgacqGH9aqpdaWc aaqaaiaadAeacaWGVbGaamOCaiaadogacaWGLbaabaGaamyqaiaadk hacaWGLbGaamyyaaaacqGH9aqpdaWcaaqaaiaad2eacaWGHbGaam4C aiaadohaaeaacaWGmbGaamyzaiaad6gacaWGNbGaamiDaiaadIgacq GHflY1caWGubGaamyAaiaad2gacaWGLbWaaWbaaSqabeaacaaIYaaa aaaaaaa@57B6@
Energy=Force⋅Length= Mass⋅Lengt h 2 Tim e 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyraiaad6 gacaWGLbGaamOCaiaadEgacaWG5bGaeyypa0JaamOraiaad+gacaWG YbGaam4yaiaadwgacqGHflY1caWGmbGaamyzaiaad6gacaWGNbGaam iDaiaadIgacqGH9aqpdaWcaaqaaiaad2eacaWGHbGaam4Caiaadoha cqGHflY1caWGmbGaamyzaiaad6gacaWGNbGaamiDaiaadIgadaahaa WcbeqaaiaaikdaaaaakeaacaWGubGaamyAaiaad2gacaWGLbWaaWba aSqabeaacaaIYaaaaaaaaaa@5ADE@
Density= Mass Volume = Mass Lengt h 3 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraiaadw gacaWGUbGaam4CaiaadMgacaWG0bGaamyEaiabg2da9maalaaabaGa amytaiaadggacaWGZbGaam4CaaqaaiaadAfacaWGVbGaamiBaiaadw hacaWGTbGaamyzaaaacqGH9aqpdaWcaaqaaiaad2eacaWGHbGaam4C aiaadohaaeaacaWGmbGaamyzaiaad6gacaWGNbGaamiDaiaadIgada ahaaWcbeqaaiaaiodaaaaaaaaa@51F6@
Acceleration= Length Tim e 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqaiaado gacaWGJbGaamyzaiaadYgacaWGLbGaamOCaiaadggacaWG0bGaamyA aiaad+gacaWGUbGaeyypa0ZaaSaaaeaacaWGmbGaamyzaiaad6gaca WGNbGaamiDaiaadIgaaeaacaWGubGaamyAaiaad2gacaWGLbWaaWba aSqabeaacaaIYaaaaaaaaaa@4C1F@
Volume=Lengt h 3 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvaiaad+ gacaWGSbGaamyDaiaad2gacaWGLbGaeyypa0JaamitaiaadwgacaWG UbGaam4zaiaadshacaWGObWaaWbaaSqabeaacaaIZaaaaaaa@42FD@
For example, using base unit [ kg ] , [ mm ] , or [ ms ] , will provide the following units force, pressure or density.
Force= Mass⋅Length Tim e 2 = [ kg ]⋅[ mm ] [ ms ] 2 =1 0 3 [ kg ]⋅[ m ] [ s ] 2 =[ kN ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiaad+ gacaWGYbGaam4yaiaadwgacqGH9aqpdaWcaaqaaiaad2eacaWGHbGa am4CaiaadohacqGHflY1caWGmbGaamyzaiaad6gacaWGNbGaamiDai aadIgaaeaacaWGubGaamyAaiaad2gacaWGLbWaaWbaaSqabeaacaaI Yaaaaaaakiabg2da9maalaaabaWaamWaaeaacaGGRbGaai4zaaGaay 5waiaaw2faaiabgwSixpaadmaabaGaaiyBaiaac2gaaiaawUfacaGL DbaaaeaadaWadaqaaiaac2gacaGGZbaacaGLBbGaayzxaaWaaWbaaS qabeaacaGGYaaaaaaakiaac2dacaGGXaGaaiimamaaCaaaleqabaGa ai4maaaakmaalaaabaWaamWaaeaacaGGRbGaai4zaaGaay5waiaaw2 faaiabgwSixpaadmaabaGaaiyBaaGaay5waiaaw2faaaqaamaadmaa baGaai4CaaGaay5waiaaw2faamaaCaaaleqabaGaaiOmaaaaaaGcca GG9aWaamWaaeaacaGGRbGaaiOtaaGaay5waiaaw2faaaaa@6FCF@
Pressure= Mass Length⋅Tim e 2 = [ kg ] [ mm ]⋅ [ ms ] 2 =1 0 9 [ kg ] [ m ]⋅ [ s ] 2 =[ GPa ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuaiaadk hacaWGLbGaam4CaiaadohacaWG1bGaamOCaiaadwgacqGH9aqpdaWc aaqaaiaad2eacaWGHbGaam4CaiaadohaaeaacaWGmbGaamyzaiaad6 gacaWGNbGaamiDaiaadIgacqGHflY1caWGubGaamyAaiaad2gacaWG LbWaaWbaaSqabeaacaaIYaaaaaaakiabg2da9maalaaabaWaamWaae aacaGGRbGaai4zaaGaay5waiaaw2faaaqaamaadmaabaGaaiyBaiaa c2gaaiaawUfacaGLDbaacqGHflY1daWadaqaaiaac2gacaGGZbaaca GLBbGaayzxaaWaaWbaaSqabeaacaaIYaaaaaaakiaac2dacaGGXaGa aiimamaaCaaaleqabaGaaGyoaaaakmaalaaabaWaamWaaeaacaGGRb Gaai4zaaGaay5waiaaw2faaaqaamaadmaabaGaaiyBaaGaay5waiaa w2faaiabgwSixpaadmaabaGaai4CaaGaay5waiaaw2faamaaCaaale qabaGaaGOmaaaaaaGccaGG9aWaamWaaeaaciGGhbGaaiiuaiaacgga aiaawUfacaGLDbaaaaa@73A4@
Energy= Mass⋅Lengt h 2 Tim e 2 = [ kg ]⋅ [ mm ] 2 [ ms ] 2 = [ kg ]⋅ [ m ] 2 [ s ] 2 =[ J ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyraiaad6 gacaWGLbGaamOCaiaadEgacaWG5bGaeyypa0ZaaSaaaeaacaWGnbGa amyyaiaadohacaWGZbGaeyyXICTaamitaiaadwgacaWGUbGaam4zai aadshacaWGObWaaWbaaSqabeaacaaIYaaaaaGcbaGaamivaiaadMga caWGTbGaamyzamaaCaaaleqabaGaaGOmaaaaaaGccqGH9aqpdaWcaa qaamaadmaabaGaai4AaiaacEgaaiaawUfacaGLDbaacqGHflY1daWa daqaaiaac2gacaGGTbaacaGLBbGaayzxaaWaaWbaaSqabeaacaaIYa aaaaGcbaWaamWaaeaacaGGTbGaai4CaaGaay5waiaaw2faamaaCaaa leqabaGaaGOmaaaaaaGccaGG9aWaaSaaaeaadaWadaqaaiaacUgaca GGNbaacaGLBbGaayzxaaGaeyyXIC9aamWaaeaacaGGTbaacaGLBbGa ayzxaaWaaWbaaSqabeaacaaIYaaaaaGcbaWaamWaaeaacaGGZbaaca GLBbGaayzxaaWaaWbaaSqabeaacaaIYaaaaaaakiaac2dadaWadaqa aiaacQeaaiaawUfacaGLDbaaaaa@706A@
Density= Mass Lengt h 3 = [ kg ] [ mm ] 2 = 10 6 ⋅ [ kg ] [ m ] 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraiaadw gacaWGUbGaam4CaiaadMgacaWG0bGaamyEaiabg2da9maalaaabaGa amytaiaadggacaWGZbGaam4CaaqaaiaadYeacaWGLbGaamOBaiaadE gacaWG0bGaamiAamaaCaaaleqabaGaaG4maaaaaaGccqGH9aqpdaWc aaqaamaadmaabaGaai4AaiaacEgaaiaawUfacaGLDbaaaeaadaWada qaaiaac2gacaGGTbaacaGLBbGaayzxaaWaaWbaaSqabeaacaaIYaaa aaaakiaac2dacaaIXaGaaGimamaaCaaaleqabaGaaGOnaaaakiabgw SixpaalaaabaWaamWaaeaacaGGRbGaai4zaaGaay5waiaaw2faaaqa amaadmaabaGaaiyBaaGaay5waiaaw2faamaaCaaaleqabaGaaGOmaa aaaaaaaa@5E74@
Check Unit
Property Card
Check the thickness unit in property if it is shell
Material Card
Check density unit
Check E-modulus
Check stress unit if possible
Load
Check force unit
Check gravity unit, if using /GRAV
Length
Measure the geometry length unit with HyperCrash or HyperMesh
All units must be consistent.
