Contact Interface Time Step
The contact interface time step is calculated in two different ways. First, based on stiffness and second, based on the velocity of the secondary nodes.
The contact interface time step based on stiffness is only calculated with TYPE7, TYPE10, TYPE11, TYPE19, TYPE21, TYPE24 and TYPE25. No matter which time step method is used, nodes that are involved in contacts have an increased stiffness which make it necessary to calculate a nodal contact interface time step using the nodal mass, interface stiffness and element stiffness.(1)
Δ t i n t e r   n o d a l = 2 M n o d a l ∑ ( K i n t e r f a c e + K e l e m e n t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqqHuoarca WG0bWaaSbaaSqaaiaadMgacaWGUbGaamiDaiaadwgacaWGYbGaaeii aiaad6gacaWGVbGaamizaiaadggacaWGSbaabeaakiabg2da9maaka aabaWaaSaaaeaacaaIYaGaamytamaaBaaaleaacaWGUbGaam4Baiaa dsgacaWGHbGaamiBaaqabaaakeaadaaeabqaamaabmaabaGaam4sam aaBaaaleaacaWGPbGaamOBaiaadshacaWGLbGaamOCaiaadAgacaWG HbGaam4yaiaadwgaaeqaaOGaey4kaSIaam4samaaBaaaleaacaWGLb GaamiBaiaadwgacaWGTbGaamyzaiaad6gacaWG0baabeaaaOGaayjk aiaawMcaaaWcbeqab0GaeyyeIuoaaaaaleqaaaaa@600A@
Where,
M nodal MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbWaaS baaSqaaiaad6gacaWGVbGaamizaiaadggacaWGSbaabeaaaaa@3C03@
Nodal mass
K interface MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGlbWaaS baaSqaaiaadMgacaWGUbGaamiDaiaadwgacaWGYbGaamOzaiaadgga caWGJbGaamyzaaqabaaaaa@3FB8@
Interface stiffness
K element MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGlbWaaS baaSqaaiaadwgacaWGSbGaamyzaiaad2gacaWGLbGaamOBaiaadsha aeqaaaaa@3DE7@
Element stiffness
The kinematic contact time step of interfaces TYPE7, TYPE11 and TYPE19 is used to make sure that a secondary node does not penetrate past a main segment during one cycle:(2)
Δ t k i n = 1 2 [ G a p − p d p d t ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqqHuoarca WG0bWaaSbaaSqaaiaadUgacaWGPbGaamOBaaqabaGccqGH9aqpdaWc aaqaaiaaigdaaeaacaaIYaaaamaadmaabaWaaSaaaeaacaWGhbGaam yyaiaadchacqGHsislcaWGWbaabaWaaSaaaeaacaWGKbGaamiCaaqa aiaadsgacaWG0baaaaaaaiaawUfacaGLDbaaaaa@48AD@
Where,
Gap MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGhbGaam yyaiaadchaaaa@3906@
Contact gap
Penetration amount
dp dt MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaWcaaqaai aadsgacaWGWbaabaGaamizaiaadshaaaaaaa@3A2F@
Relative velocity of the penetrating secondary node (or line for TYPE11 contact) with respect to the main segment (or line for TYPE11 contact).
