Sol2SPH Particle Behavior
All particles are created at the beginning of the calculation.
As long as their main element is not deleted, those particles are unreleased.
When the main solid element is deleted, the particles are released and behave like any other SPH genuine particle.
Unreleased particles kinematic is interpolated from their main element. In turn, the forces applied to those particles are transmitted to their corresponding solid nodes.
Those forces are:
  • Contact forces if they are secondary of a TYPE7 interface or rigid walls
  • Interaction forces with released particles or genuine particles.
Particle Activation Process
Particles are fully activated based on the following criteria.
  • Their main brick is deleted either because:
    • The minimum time step has been reached (/DT/BRICK/DEL)
    • The failure criteria associated to the brick material law has been met
  • In case of contact:
    • If an unreleased particle is secondary of a TYPE7 interface and enters the gap of the main surface, the brick is deleted, and the associated particles are released provided the Ibag flag of the interface is set to 1.
    • If an unreleased particle is within interaction distance of any particle belonging to a different part (including unreleased particles), the main brick is deleted, and the associated particles are released. Therefore, no contact interface is required between two Sol2SPH parts.
      Figure 1. Orange Particles are Released as they are within Interaction Distance of the Yellow Particle. (which belongs to another part)
    • If Isol2sph is set to 2 in /SPHGLO, then particles are not released if the 2 parts belong to the same subset. This option can be useful to prevent unwanted activation of particles at the junction of parts belonging the same physical entities.
      Figure 2. Isol2sph = 1: Unwanted particles activation / Isol2sph = 2 + subset definition
Particle properties are defined using /PROP/SPH option.
Typical Property for Sol2SPH Particles:
/PROP/TYPE34/10
SPH prop example
#                 mp                  qa                  qb            alpha_cs   skew_ID      h_ID
                   0                   0                   0                   0         0         0
#    order                   h             xi_stab
         0               125.0                   0
The mass of the particles is automatically recalculated from the main element to ensure mass conservation. For this type of SPH part, the input mass may be 0.0.
The smoothing length must be input. A good value for a regular mesh is: (1)
h = 1.5 ⋅ l N d i r
Where,
h
Smoothing length
l
Size of the brick elements
N d i r
Number of particles per direction for each solid elements
The material law can be /MAT/LAW2, /MAT/LAW3, /MAT/LAW4, /MAT/LAW6, /MAT/LAW12, /MAT/LAW21, /MAT/LAW24, /MAT/LAW36, /MAT/LAW49, or /MAT/LAW81.
Both material laws for solid and SPH must be of the same type.
The material parameters can be different, but make sure there is consistency.
It is advised to keep the same parameters and change only the failure values (failure criteria, max strain, Spalling pressure, ...).
