Monitored Volume Time Step
An "AIRBAG1" time step is estimated into the Engine, but this time step will never control the time step during the run. If that is the case, it means there is a non-physical airbag definition in the input deck.
Element Time Step Control
- /DT/AIRBAG
- Defines and for airbags
- /DT/FVMBAG
- Defines and for Finite Volume Method airbag
/DT/FVMBAG is only used for monitored volumes type /MONVOL/FVMBAG1. The and can be defined to insure stability and a minimum time step size by triggering additional finite volume merges when the FVMBAG1 entity penalizes the computation. /DT/FVMBAG/1 is used to merge finite volumes when .
