User Subroutines
How to check MinGW version you used?
gcc –v
or gfortran –v
to check the MinGW version.
Message indicates a successful installation of the freeware win64 Fortran compiler.
How to compile Starter and Engine file with MinGW?
Figure 3.
build_userlib_win64_gfortran.bat
Figure 4.
Figure 5.
Figure 6.
Figure 7.
How to import your user material law in HyperCrash?
- Copy the MF_GenYld_29.cfg file to your HyperWorks installation directory: ~\hw\hc\config\CFG\Version\MAT
- Edit the file data_hierarchy.cfg in the directory ~\hw\hc\config\CFG\Version.
- Add the following
lines:
HIERARCHY { KEYWORD = MAT_ELASTO_PLASTIC_LAW30; TITLE = "Mat User2 (30)"; FILE = "MAT/Mat_User2.cfg"; SUBTYPE = USER; USER_ID = 30; USER_NAMES = (LAW30,USER2); }
determines where the configured law
will be organized in the menu when creating a new material law in the Materials panel.
determines what the configured law will be named
Figure 8.
How to launch Radioss model with your user subroutine?
Just copy your libraduser_win64.dll file in the same directory where you put your Radioss model.
For example, we put Radioss model in D:\99_temp\User_Subroutine_example\RADIOSS_RUN. Then copy libraduser_win64.dll file in this directory.
./ s_14.0_win64.exe -i main_TEST4_0000.rad
./ e_14.0_win64.exe -i main_TEST4_0001.rad
Figure 9.
Figure 10.
