Access the Model Files
Required model files for the models you build.
- The Radioss
verification problem model files are located on
<install_directory>/hwsolvers/demos/radioss/verification. Note: The files may require unzipping before proceeding with the verification problem. When extracting zipped files, preserve any directory structure included in the file package.
