OS-V: 0455 Simply-Supported Solid Square Plate
Test No. FV52 A well-established solid square plate, which contains three rigid modes with the given boundary condition. The test examines the performance of OptiStruct Normal Modes Analysis on 3D solid elements.
fv52
Figure 1. FE Model with Boundary Conditions and Loadcases
Benchmark Model
The HEXA 8-node and HEXA 20-node solid elements are used in test FV52. An 8x8x3 mesh configuration is used for HEXA 8-node elements, and a 4x4x1 mesh configuration is used with HEXA 20-node elements. The z-directional displacement is constrained at Z = -5m plane along the four edges of the plate.
The material properties are:
Property
Value
E
200 x 109 N/m2
υ
0.3
ρ
8000 kg/m3
Modal Analysis Results
The frequency of each targeted mode is normalized with the closed form solution.
f*
Closed form solution.
Mode 4 Modes 5 and 6 Mode 7
fv52a_high fv52b_high fv52c_high
f*
HEXA20
HEXA8
45.897 Hz
0.9760
0.9874
f*
HEXA20
HEXA8
109.44 Hz
1.0101
1.0413
f*
HEXA20
HEXA8
265.81 Hz
1.0072
1.0322
Mode 8 Modes 9 and 10
fv52d_high fv52e_high
f*
HEXA20
HEXA8
193.59 Hz
1.0017
1.0164
f*
HEXA20
HEXA8
206.19 Hz
1.0022
1.0164
Model Files
The model files used in this problem include:
<install_directory>/hwsolvers/demos/optistruct/verification
  • /fv52_HOE.fem
  • /fv52_LOE.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
