OS-V: 0425 Clamped Thin Rhombic Plate
Test No. FV15 The behavior of distorted thin elements in normal modes analysis is examined using OptiStruct.
Benchmark Model
The 4-node quad elements with 12x12 mesh configuration are used to model the thin rhombic plate. The x-translation, y-translation displacements, and z-rotational displacements are fixed for all of the nodes. In addition, the z-translation, x-rotational and y-rotational are fixed for the nodes along the four edges.
- Property
- Value
- E
- 200 x 109 N/m2
- 0.3
- 8000 kg/m3
Modal Analysis Results
f*
- Closed form solution
Mode 1 | Mode 2 | Mode 3 | |||
f* CQUAD4 |
7.938 Hz 0.9798 |
f* CQUAD4 |
12.835 Hz 1.0079 |
f* CQUAD4 |
17.941 Hz 1.0182 |
Mode 4 | Mode 5 | Mode 6 | |||
f* CQUAD4 |
19.133 Hz 0.9629 |
f* CQUAD4 |
24.009 Hz 1.0339 |
f* CQUAD4 |
27.922 Hz 1.0036 |
Model Files
- <install_directory>/hwsolvers/demos/optistruct/verification/fv15.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
