ardi.item
Report Item: access/modify Report Items.
ardi.item.chapter
Interact with items of type chapter. This item type is valid only for document reports.
Supported property names are:-name-value-parent-type (read only).
All properties available can be passed via the "create" API or modified on an existing item via the "set" API.
ardi.item.chapter.create
Creates an item of type "chapter".
- Syntax
- Parameters
- For
- Value: A full list of property names see "Supported property names" above.
- Returns
- The ID of the item or Python-error in case an error occurred during creation.
- Example
ardi.item.chapter.create -name "My Chapter Item"
ardi.item.chapter.delete
Deletes the item with the specified ID.
- Syntax
- Parameters
- -id
- Mandatory value: Item ID. The item ID which is returned by the corresponding "create" API.
- Returns
- 1 for OK, Python-error in case of error.
- Example
ardi.item.chapter.delete -id $id
ardi.item.chapter.get
Queries the value of one property.
- Syntax
- Parameters
- -id
- For
- Returns
- The value of the specified property or Python-error in case of error.
- Example
ardi.item.chapter.get -id $id -property parent
ardi.item.chapter.set
Sets one or multiple parameters to specified values. The type of the item is assigned upon creation and cannot be changed after.
- Syntax
- Parameters
- -id
- Mandatory Value: Item ID. The item ID which is returned by the corresponding "create" API.
- For
- Returns
- Example
ardi.item.chapter.set -id $id -name "My Chapter Item" -value "Good monring, how are you today?"
ardi.item.chapter.hasproperty
Check if the item has property with specified key.
- Syntax
- Parameters
- -id
- Value: Item ID.
- -key
- Value: Property key.
- Returns
- 1 if valid, 0 if invalid.
ardi.item.exceldocument
Interact with items of type exceldocument.
Supported property names are:-name-value-parent-type (read only)-file-sheet-caption-capitalisation.
ardi.item.exceldocument.create
Creates an item of type "exceldocument".
- Syntax
- Parameters
- For
- Returns
- Example
ardi.item.exceldocument.create -name "My External Excel Document Item"
ardi.item.exceldocument.delete
- Syntax
- Parameters
- -id
- Returns
- Example
ardi.item.exceldocument.delete -id $id
ardi.item.exceldocument.get
- Syntax
- Parameters
- -id
- For
- Returns
- Example
ardi.item.exceldocument.get -id $id -property parent
ardi.item.exceldocument.getcell
Queries the value of one property from table cell.
- Syntax
- Parameters
- -id
- -row
- Mandatory value: Row ID. Row ID is an integer starting from 0.
- -column
- Mandatory value: Column ID. Column ID is an integer starting from 0.
- -property
- Mandatory value: Property name. 'value' or 'href'
- Returns
- Example
ardi.item.exceldocument.getcell -id $id -row 0 -column 0 -property values
ardi.item.exceldocument.getpropertyid
Queries id of property.
- Syntax
- Parameters
- -id
- Value: Item ID.
- -key
ardi.item.exceldocument.getpropertykeylist
Queries list of properties.
- Syntax
- Parameters
- -id
- -row
- Value: Item ID.
- Returns
- List of property keys for a particular item ID.
ardi.item.exceldocument.set
- Syntax
- Parameters
- -id
- For
- Returns
- Example
ardi.item.exceldocument.set -id $id -name "My External Excel Document" -file "c:/temp/mydoc.xlsx"
ardi.item.exceldocument.setcell
Sets one or multiple parameters to table cell.
- Syntax
- Parameters
- -id
- -row
- -column
- -value
- Value: The value you want to set on the cell.
- -href
- Value: Object ID to hyperlink.
- Returns
- Example
ardi.item.exceldocument.setcell -id $id -row 0 -column 0 -value "Hello" -href $refobjid
ardi.item.image
Interact with items of type image.
Supported property names are:-name-value-parent-type (read only)-config-hwpage-hwwindow.
ardi.item.image.create
Creates an item of type "image".
- Syntax
- Parameters
- For
- Returns
- Example
ardi.item.image.create -name "My Image Item"
ardi.item.image.delete
- Syntax
- Parameters
- -id
- Returns
- Example
ardi.item.image.delete -id $id
ardi.item.image.get
- Syntax
ardi.item.image.get
- Parameters
- -id
- For
- Returns
- Example
ardi.item.image.get -id $id -property parent
ardi.item.image.set
- Syntax
ardi.item.image.set
- Parameters
- -id
- For
- Returns
- Example
ardi.item.image.set -id $id -name "My Image Item" -value "Good monring, how are you today?"
ardi.item.module
ardi.item.module.create)
Creates an item of type "module".
- Syntax
ardi.item.module.delete
- Syntax
- Parameters
- -id
- Returns
ardi.item.module.get
Gets property value of an Item.
- Syntax
ardi.item.module.set
Sets property value of an Item.
- Syntax
ardi.item.pagebreak
ardi.item.pagebreak.create
Creates an item of type "break".
- Syntax
- Parameters
- For
- Returns
- Example
ardi.item.pagebreak.create -name "My Image Item"
ardi.item.pagebreak.delete
- Syntax
- Parameters
- -id
- Returns
- Example
ardi.item.pagebreak.delete -id $id
ardi.item.pagebreak.get
- Syntax
- Parameters
- -id
- For
- Returns
- Example
ardi.item.pagebreak.get -id $id -property parent
ardi.item.pagebreak.set
- Syntax
- Parameters
- -id
- For
- Returns
- Example
ardi.item.pagebreak.set -id $id -name "My Image Item" -value "Good monring, how are you today?"
ardi.item.property
ardi.item.property.create
Creates an item of type "property".
- Syntax
- Parameters
- -id
- Mandatory value: Parent item ID of type text, image, table, module\parent.
- -key
- Mandatory value: Unique key/name for the property.
- -name
- Value: "Display name of the property, if not specified key is used as display name".
- -type
- (defaults to str): Type of property.
- For
- Returns
- Example
ardi.item.property.create -id $parentid -key "MyKey" -name "My Property" -value "My Value" -type "str"
ardi.item.property.delete
- Syntax
- Parameters
- -id
- Mandatory value: Parent item ID of type text,image,table,module etc, \parem
- -name
- Mandatory value: Name of the property.
- Returns
- Example
ardi.item.property.delete -id $id
ardi.item.property.get
- Syntax
- Parameters
- -id
- For
- -column
- -property
- Returns
- Example
ardi.item.property.get -id $id -property parent
ardi.item.property.set
Sets name and value of specific property.
- Syntax
- Parameters
- -id
- For
- Returns
- Example
ardi.item.property.set(id=itemid,value="Test")
ardi.item.slide
ardi.item.slide.create
Creates an item of type "slide".
- Syntax
- Parameters
- For
- Returns
- Example
ardi.item.slide.create -name "My Slide Item"
ardi.item.slide.delete
- Syntax
- Parameters
- -id
- Returns
- Example
ardi.item.slide.delete(id=itemid)
ardi.item.slide.get
- Syntax
ardi.item.slide.get
- Parameters
- -id
- For
- Returns
- Example
ardi.item.slide.get -id $id -property parent
ardi::item::slide set
- Syntax
- Parameters
- -id
- For
- Returns
- Example
ardi.item.slide.set(id=itemid,name="My Slide Item",value="Good monring, how are you today?")
ardi.item.table.
Interact with items of type table.
Supported property names are:-name-value-parent-type (read only)-numberless-numberofcolumns -showcolumnheader-showrowheader.
ardi.item.table.create
Creates an item of type "table".
- Syntax
- Parameters
- For
- Returns
- Example
ardi.item.table.create -name "My Table Item"
ardi.item.table.delete
- Syntax
- Parameters
- -id
- Returns
- Example
ardi.item.table.delete -id $id
ardi.item.table.get
- Syntax
ardi.item.table.get
- Parameters
- -id
- For
- Returns
- Example
ardi.item.table.get -id $id -property parent
ardi.item.table.getcell
Queries the value on a cell identified by row and column ID. Row and column IDs start with 0.
- Syntax
- Parameters
- -id
- -row
- Mandatory value: Row ID. The ID of the row.
- -column
- Mandatory value: Column ID. The ID of the column.
- -property
- Mandatory value: 'value', 'href', 'color', 'textcolor', 'fontname', 'fontstyle', 'horizontal_alignment' and 'vertical_alignment'.
- Returns
- The value of the cell, Python-error in case of error.
- Example
ardi.item.table.getcell(id=itemid,row=0,column=0)
ardi.item.table.getheader
Queries the header text on a row or on a column. Row and column IDs start with 1. Specify either row or column ID to query the current value.
- Syntax
- Parameters
- -id
- -row
- Value: Row ID. The ID of the row you want to query the header text.
- -column
- Value: Column ID. The ID of the column you want to query the header text.
- Returns
- The header text, Python-error in case of error.
- Example
ardi.item.table.getheader -id $id -column 1
ardi.item.table.set
- Syntax
ardi.item.table.set
- Parameters
- -id
- For
- -column
- Returns
- Example
ardi.item.table.set -id $id -name "My Table Item" -value "Good monring, how are you today?"
ardi.item.table.setcell
Sets the value on a cell identified by row and column ID. Row and column IDs start with 0.
- Syntax
- Parameters
- -id
- -row
- -column
- -value
- -href
- Value: Object ID to set cross-reference to.
- Returns
- Example
ardi.item.table.setcell -id $id -column 1 -value "My Header Text on column 1"
ardi.item.table.setheader
Sets the header text on a row or on a column. Row and column IDs start with 0. Specify either row or column ID to set the header text to desired value.
- Syntax
- Parameters
- -id
- -row
- Value: Row ID. The ID of the row you want to set a particular header text.
- -column
- Value: Column ID. The ID of the column you want to set a particular header text.
- -value
- Value: The text you want to set as header of the specified row or column ID.
- Returns
- Example
ardi.item.table.setheader(id=itemid,column=1,value="My Header Text on column 1") i.e ardi.item.table.setheader(id=itemid,row=2,value="My Row Header")
ardi.item.tableofreference
Interact with items of type tableofreference.
Supported property names are: -name-value-parent.
All properties available can be passed via the "create" API or modified on an existing item via the "set" API. After creation all the properties that applies for table type can be used.
ardi.item.tableofreference.create
Creates an item of type "tableofreference".
- Syntax
- Parameters
- For
- Returns
- The ID of the item type table or Python-error in case an error occurred during creation.
ardi.item.tableofreference.delete
- Syntax
- Parameters
- -id
- Returns
- Example
ardi.item.tableofreference.delete(id=itemid)
ardi.item.tableofreference.get
- Syntax
- Parameters
- -id
- For
- Returns
- Example
ardi.item.tableofreference.get(id=itemid,property='parent')
ardi.item.tableofreference.set
- Syntax
- Parameters
- -id
- For
- Returns
- 1 for OK, python-error in case of error.
- Example
ardi.item.tableofreference.set(id=itemid,name="My Table of References" -parent $parentid"
ardi.item.text
Interact with items of type text.
ardi.item.text.create
Creates an item of type "text".
- Syntax
- Parameters
- For
- Returns
- Example
ardi.item.text.create(name="Text1",value="My Text Content")
ardi.item.text.delete
- Syntax
- Parameters
- -id
- Returns
- Example
ardi.item.text delete(id=itemid)
ardi.item.text.get
- Syntax
ardi.item.text.get
- Parameters
- -id
- For
- Returns
- Example
ardi.item.text.get(id=itemid,property='parent')
ardi.item.text.getcrossref
Queries the cross reference within text item.
- Syntax
- Parameters
- -id
ardi.item.text.set
- Syntax
ardi.item.text.set
- Parameters
- -id
- For
- Returns
- 1 for OK, -Python-error in case of error.
- Example
ardi.item.text.set(id=itemid,name="My Text Item",value="Good monring, how are you today?")
ardi.item.text.setcrossref
Sets the cross reference within text item.
- Syntax
ardi.item.textdocument
Interact with items of type textdocument.
Supported property names are:-name-file-parent.
ardi.item.textdocument.create
Creates an item of type "textdocument".
- Syntax
- Parameters
- For
- Returns
- Example
ardi.item.textdocument.create(name="My Text File",file="example.txt")
ardi.item.textdocument.delete
- Syntax
- Parameters
- -id
- Returns
- Example
ardi.item.textdocument.delete(id=itemid)
ardi.item.textdocument.get
- Syntax
- Parameters
- -id
- For
- Returns
- Example
ardi.item.textdocument.get(id=itemid,property='parent')
ardi::item::textdocument.set
- Syntax
- Parameters
- -id
- For
- Returns
- Example
ardi.item.textdocument.set(id=itemid,name="My External Excel Document",file= "c:/temp/textdocument.txt")
ardi.item.worddocument
Interact with items of type worddocument.
ardi.item.worddocument.create
Creates an item of type "worddocument".
- Syntax
- Parameters
- For
- Returns
- The ID of the item or python-error in case an error occurred during creation.
- Example
ardi.item.worddocument.create(name="My Word Document",file="example.docx")
ardi.item.worddocument.delete
- Syntax
- Parameters
- -id
- Returns
- Example
ardi.item.worddocument.delete(id=itemid)
ardi.item.worddocument.get
- Syntax
- Parameters
- -id
- For
- Returns
- Example
ardi.item.worddocument.get(id=itemid,property='parent')
ardi.item.worddocument.set
- Syntax
- Parameters
- -id
- For
- Returns
- Example
ardi.item.worddocument.set(id=itemid,name="My External Word Document",file ="c:/temp/example.docx"
ardi.item.apply
For better performance data created, manipulated or deleted go into a cache.
- Syntax
ardi.item.apply
- Parameters
- -name
- Value: Layout name to use in case of presentation.
- -itemlist
- Value: List of item ids to apply.
- -parent
- Value: parent of the cached items. If not specified root item will act as a parent. This API processes the cached data, clears the cache and redraws the GUI if needed.
- -property
- Mandatory value: Property name. 'value' or 'href'.
- Returns
ardi.item.delete
- Syntax
ardi.item.delete
- Parameters
- -id
- Value: Item ID.
- Returns
ardi.item.get
Queries the value of one property or role or attribute.
- Syntax
ardi.item.get
- Parameters
- -id
- For
- Returns
- The value of the specified property/role/attribute or python-error in case of error.
- Example
ardi.item.get -id $id -property parent
ardi.item.getpropertyid
Queries ID of property.
- Syntax
- Parameters
- -id
- Value: Item ID.
ardi.item.getpropertykeylist
- Syntax
- Parameters
- -id
- Value: Item ID.
- Returns
ardi.item.getslidelayouts
Queries slide based layouts.
- Syntax
- Returns
- The list of slide layout IDs.
ardi.item.getmasterlayouts
Queries master layouts.
- Syntax
- Returns
- The list of master layout ID's.
ardi.item.gettype
Queries the type of the item with the specified ID.
- Syntax
ardi.item.gettype
- Parameters
- -id
- Value: Item ID.
- Returns
- The type of the item.
ardi.item.gettypelist
Queries available types of items.
- Syntax
- Returns
- A list of item types.
ardi.item.hasproperty
- Syntax
- Parameters
- -id
- Value: Item ID.
- -key
- Returns
ardi.item.isvalid
Check if the item with the specified ID is valid.
- Syntax
ardi.item.isvalid
- Parameters
- -id
- Value: Item ID.
- Returns
ardi.item.set
- Syntax
ardi.item.set
- Parameters
- -id
- For
- Value: A full list of standard property names see "Supported property names" above. Use rpti::item getpropertykeylist for list of dynamic properties.
- Returns
- Example
ardi.item.set -id $id -name "My Text Item" -value "Good monring, how are you today?"
