Select Solver Execution Scripts
Select the solver execution script you would like HyperStudy to use when executing the model.
A set of default solver codes are registered in HyperStudy. You will need to register solver scripts if the solver is not a HyperWorks solver and hence is not registered by default, or in cases where you need to perform a series of actions such as copying files, running one or more solvers, and extracting data.
In the Define Models step, Solver Execution Script column of the model you are defining, select a solver script.
