Pareto Plot Post Processing
Plot the effects of input variables on output responses in hierarchical order (highest to lowest).
Plot the Effects of Variables on Responses in Hierarchical Order
Rank the effects of input variables on output responses in hierarchical order (highest to lowest) in the Pareto Plot post processing tab.
  1. From the Post Processing step, click the Pareto Plot tab.
  2. Using the Channel selector, select the response to plot.
    Tip: Analyze multiple responses simultaneously by switching the Multiplot option to (multiple plots) and selecting the responses to plot using the Channel selector.
  3. Analyze the pareto plot.
    The effect of input variables on output responses is indicated by bars. Hashed lines with a positive slope indicates a positive effect. If an input variable increases, the output response will also increase. Hashed lines with a negative slope indicates a negative effect. Increasing the input variable lowers the output response.
    A line represents the cumulative effect.
Configure the pareto plot's display settings by clicking (located in the top, right corner of the work area). For more information about these settings, refer to Pareto Plot Tab Settings.
Settings to configure the plots displayed in the Pareto Plot post processing tab.
Access settings from the menu that displays when you click (located above the Channel selector).
Effect curve
Show line to represent the cumulative effect.
# Top factors displayed
Specify the number of input variables (bars) displayed in the plot.
Note: This settings does not change the calculated effects.
Multivariate Effects
Calculate the effect using all input variables simultaneously.
Linear Effects
Calculate the effect using each input variable independently.
For more information about linear effects, refer to Linear Effects Post Processing.
Include Interactions
Include first order, two way interactions along with first order effects, and calculate interactions consistently with the choice of linear or multi-variate effects.
For more information about interactions, refer to Interactions Post Processing.
Exclude dependent/linked inputs
Only show the independent input variables.
Tip: Excluding dependent/link inputs reduces redundant information.
Multivariate effect of an input variable is the difference between the output response values when the variable is at its lower and upper values while the remaining variables are at fixed values. All calculations are based on a single linear regression model including all variables.
A system with two variables, X and Y, and the output response, F (X,Y).
Table 1. Design Matrix
Run X Y F (X, Y)
1 42.0 108.0 1385.4
2 54.0 156.0 2290.2
3 66.0 84.0 3421.2
4 78.0 132.0 4778.3
5 32.4 165.6 824.4
6 44.4 93.6 1548.3
F (X, Y) = A+B*X+C*Y MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeOraiaabc cacaqGOaGaaeiwaiaabYcacaqGGaGaaeywaiaabMcacaqGGaGaaeyp aiaabccacaqGbbGaae4kaiaabkeacaqGQaGaaeiwaiaabUcacaqGdb GaaeOkaiaabMfaaaa@4481@ is the reference regression model and intercept. A and coefficients, B and C, are calculated using the data set above.
A = - 2609.8
B = 88.6
C = 2.5
Regression equation: F (X, Y) = -2609 .8 + 88 .6*X + 2 .5*Y MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeOraiaabc cacaqGOaGaaeiwaiaabYcacaqGGaGaaeywaiaabMcacaqGGaGaaeyp aiaabccacaqGTaGaaeOmaiaabAdacaqGWaGaaeyoaiaab6cacaqG4a GaaeiiaiaabUcacaqGGaGaaeioaiaabIdacaqGUaGaaeOnaiaabQca caqGybGaaeiiaiaabUcacaqGGaGaaeOmaiaab6cacaqG1aGaaeOkai aabMfaaaa@4EB5@
  • Effect of X (lower = 32.4, upper = 78.0)
    X = 32.4, Y = 100
    F   32.4 ,   100   =   − 2609.8   +   88.6 * 32.4   +   2.5 * 100   =   360.84 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGgbGaaeiia8aadaqadaqaa8qacaaIZaGaaGOmaiaac6cacaaI 0aGaaiilaiaabccacaaIXaGaaGimaiaaicdaa8aacaGLOaGaayzkaa WdbiaabccacqGH9aqpcaqGGaGaeyOeI0IaaGOmaiaaiAdacaaIWaGa aGyoaiaac6cacaaI4aGaaeiiaiabgUcaRiaabccacaaI4aGaaGioai aac6cacaaI2aGaaiOkaiaaiodacaaIYaGaaiOlaiaaisdacaqGGaGa ey4kaSIaaeiiaiaaikdacaGGUaGaaGynaiaacQcacaaIXaGaaGimai aaicdacaqGGaGaeyypa0JaaeiiaiaaiodacaaI2aGaaGimaiaac6ca caaI4aGaaGinaaaa@5DF5@
    X = 78, Y = 100
    F   78 ,   100   =   − 2609.8   +   88.6 * 78   +   2.5 * 100   =   4401 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGgbGaaeiia8aadaqadaqaa8qacaaI3aGaaGioaiaacYcacaqG GaGaaGymaiaaicdacaaIWaaapaGaayjkaiaawMcaa8qacaqGGaGaey ypa0JaaeiiaiabgkHiTiaaikdacaaI2aGaaGimaiaaiMdacaGGUaGa aGioaiaabccacqGHRaWkcaqGGaGaaGioaiaaiIdacaGGUaGaaGOnai aacQcacaaI3aGaaGioaiaabccacqGHRaWkcaqGGaGaaGOmaiaac6ca caaI1aGaaiOkaiaaigdacaaIWaGaaGimaiaabccacqGH9aqpcaqGGa GaaGinaiaaisdacaaIWaGaaGymaaaa@59B1@
    Δ F   =   4401   −   360.84   = 4 0 4 0 . 1 6 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacqqHuoarcaWGgbGaaeiiaiabg2da9iaabccacaaI0aGaaGinaiaa icdacaaIXaGaaeiiaiabgkHiTiaabccacaaIZaGaaGOnaiaaicdaca GGUaGaaGioaiaaisdacaqGGaGaeyypa0JaaCinaiaahcdacaWH0aGa aCimaiaac6cacaWHXaGaaCOnaaaa@4ADD@
  • Effect of Y (lower = 84, upper = 165.6)
    X = 50, Y = 84
    F   50 ,   84   =   − 2609.8   +   88.6 * 50   +   2.5 * 84   =   2030.2 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGgbGaaeiia8aadaqadaqaa8qacaaI1aGaaGimaiaacYcacaqG GaGaaGioaiaaisdaa8aacaGLOaGaayzkaaWdbiaabccacqGH9aqpca qGGaGaeyOeI0IaaGOmaiaaiAdacaaIWaGaaGyoaiaac6cacaaI4aGa aeiiaiabgUcaRiaabccacaaI4aGaaGioaiaac6cacaaI2aGaaiOkai aaiwdacaaIWaGaaeiiaiabgUcaRiaabccacaaIYaGaaiOlaiaaiwda caGGQaGaaGioaiaaisdacaqGGaGaeyypa0JaaeiiaiaaikdacaaIWa GaaG4maiaaicdacaGGUaGaaGOmaaaa@59A9@
    X = 50, Y = 165.6
    F   50 ,   165.6   =   − 2609.8   +   88.6 * 50   +   2.5 * 165.6   =   2234.2 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacaWGgbGaaeiia8aadaqadaqaa8qacaaI1aGaaGimaiaacYcacaqG GaGaaGymaiaaiAdacaaI1aGaaiOlaiaaiAdaa8aacaGLOaGaayzkaa WdbiaabccacqGH9aqpcaqGGaGaeyOeI0IaaGOmaiaaiAdacaaIWaGa aGyoaiaac6cacaaI4aGaaeiiaiabgUcaRiaabccacaaI4aGaaGioai aac6cacaaI2aGaaiOkaiaaiwdacaaIWaGaaeiiaiabgUcaRiaabcca caaIYaGaaiOlaiaaiwdacaGGQaGaaGymaiaaiAdacaaI1aGaaiOlai aaiAdacaqGGaGaeyypa0JaaeiiaiaaikdacaaIYaGaaG4maiaaisda caGGUaGaaGOmaaaa@5E07@
    Δ F   =   2234.2   −   2030.2   = 2 0 4   MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacqqHuoarcaWGgbGaaeiiaiabg2da9iaabccacaaIYaGaaGOmaiaa iodacaaI0aGaaiOlaiaaikdacaqGGaGaeyOeI0Iaaeiiaiaaikdaca aIWaGaaG4maiaaicdacaGGUaGaaGOmaiaabccacqGH9aqpcaWHYaGa aCimaiaahsdacaGGGcaaaa@4A7D@
Input Variable Multivariate Effect
X 4040.16
Y 204
