Edit Mesh Type and Mapping Method Use the Interactive: Face Edit tool to edit the mesh type and mapping method of individual surfaces. Before you begin, use the Interactive: Create tool to define a meshing area by selecting surfaces, and create an initial mesh. From the Mesh ribbon, click the Interactive > Face Edit tool. Figure 1. Optional: On the guide bar, click to define surface mesh options. Select the surface(s) to edit. In the microdialog, select a mesh type and mapping method to apply to the selected edge(s). On the guide bar, click Update Tip: Clear your selection by left-clicking in empty space.
