Create Surface Mesh by Defining Size Use the Surface tool to interactively create mesh on select surfaces by defining element size. The mesh generated will adhere to any previously defined mesh controls. From the Mesh ribbon, click the Surface tool. Figure 1. Optional: On the guide bar, click to define surface mesh options. Select surfaces. Click Mesh on the guide bar or the microdialog. Surface mesh is created.
