Response File Properties
General properties
Variable Definition
ACCEPT_EULA
  • YES: You accept the terms of the License Agreement and it allows you to proceed with Flux installation
  • NO: You do not accept the terms of the License Agreement and Flux will not be installed
USER_INSTALL_DIR The default install folder is /home/<username>/2021.1/altair
SET_START_MENU_FOLDER Specify the name of the start menu folder
INSTALL_DESKTOP_SHORTCUTS
  • 0: No shortcuts are created
  • 1: Shortcuts are created
