Flow Simulator
Flow Simulator
2021.1
  1. Home
  2. Solver Technical Manual
  3. Elements
  • What's New
  • Get Started
  • Tutorials
  • Quick Start Guide
  • Graphical User Interface
  • Solver Technical Manual
  • FlowSimulator General Guide
Flow Simulator
2021.1
Flow Simulator
  • What's New
    View new features for Flow Simulator 2021.
  • Get Started
    Flow Simulator is an integrated flow, heat transfer, and combustion design software that enables multidisciplinary engineering simulations to optimize machine design
  • Tutorials
    Discover Flow Simulator functionality with interactive tutorials.
  • Quick Start Guide
    • General Overview
    • Inbuilt Material Properties
    • Chambers
    • Elements
      • Elements Overview
      • Advanced Orifice Element
      • Bearing Elements
      • Bend Elements
      • Brush Seal Element
      • Centrifugal Pump Elements
      • Combination Flow Elements
      • Combustion Element
      • Diffuser Element
      • Effective Area Orifice Elements
      • Elevation Element
      • Fan, Compressors & Turbine Elements
      • FI CdComp Elements
      • Fixed Flow Elements
      • Incompressible Tube Element
      • Junction Elements
      • Naca Scoop Element
      • Orifice Element
      • Orifice Plates
      • Positive Displacement Pump Element
      • Spline Seal Element
      • Supersonic Tube
      • Transition Elements
      • Tube Elements
      • Turbulator Passage Elements
      • Valve Elements
      • Verme Seal Element
      • Vortex Elements
      • WSeal Element
    • Components
    • Cavities
    • Thermal Network
    • Controllers
    • User Defined Element (UDE)
    • General Functions & Routines
    • References
Flow Simulator
Flow Simulator
2021.1
  1. Home
  3. Elements
  • What's New
  • Get Started
  • Tutorials
  • Quick Start Guide
Elements
  1. Elements Overview
  2. Advanced Orifice Element
  3. Bearing Elements
  4. Bend Elements
  5. Brush Seal Element
  6. Centrifugal Pump Elements
  7. Combination Flow Elements
  8. Combustion Element
  9. Diffuser Element
  10. Effective Area Orifice Elements
  11. Elevation Element
  12. Fan, Compressors & Turbine Elements
  13. FI CdComp Elements
  14. Fixed Flow Elements
  15. Incompressible Tube Element
  16. Junction Elements
  17. Naca Scoop Element
  18. Orifice Element
  19. Orifice Plates
  20. Positive Displacement Pump Element
  21. Spline Seal Element
  22. Supersonic Tube
  23. Transition Elements
  24. Tube Elements
  25. Turbulator Passage Elements
  26. Valve Elements
  27. Verme Seal Element
  28. Vortex Elements
  29. WSeal Element
