Currents and Charges
Currents and charges data are supported for triangles and wire segments and can be requested from CADFEKO or with the OS card.
Currents on Triangles
VALUES OF THE CURRENT DENSITY VECTOR ON TRIANGLES in A/m (no averaging)
Triangle centre JX JY ...
number x/m y/m z/m magn. phase magn. phase ...
1 1.11111E-01 1.11111E-01 0.00000E+00 1.099E-02 147.51 1.099E-02 147.51 ...
2 1.01903E-01 8.28341E-01 0.00000E+00 1.955E-04 62.22 4.668E-03 121.95 ...
3 1.99385E-01 6.49031E-01 0.00000E+00 2.036E-03 131.69 5.377E-03 128.94 ...
4 9.40494E-02 1.16528E+00 0.00000E+00 1.019E-04 29.26 3.685E-03 109.98 ...
5 8.89886E-02 1.49041E+00 0.00000E+00 8.437E-05 -33.65 2.744E-03 100.59 ...
JZ Current magnitude in the
magn. phase 3 corner points
1.099E-02 147.51 1.495E-02 3.067E+00 1.495E-02
4.668E-03 121.95 4.520E-03 4.695E-03 4.842E-03
5.377E-03 128.94 5.591E-03 6.001E-03 5.709E-03
3.685E-03 109.98 3.697E-03 3.718E-03 3.660E-03
2.744E-03 100.59 2.768E-03 2.630E-03 2.850E-03
Charges on Triangles
VALUES OF THE SURFACE CHARGE DENSITY ON TRIANGLES in As/m^2
Triangle SIGMA
number magn. phase
1 2.03115E-11 165.31
2 8.14289E-12 152.22
3 1.00211E-11 160.36
4 4.59629E-12 119.26
5 4.02388E-12 56.35
Currents on Wire Segments
VALUES OF THE CURRENT IN THE SEGMENTS in A Segment centre IX IY IZ number x/m y/m z/m magn. phase magn. phase magn. phase 1 0.000E+00 0.000E+00 1.66551E-01 0.00E+00 0.00 0.00E+00 0.00 1.837E-02 -31.39 2 0.000E+00 0.000E+00 4.99654E-01 0.00E+00 0.00 0.00E+00 0.00 1.410E-02 -33.86 3 0.000E+00 0.000E+00 8.32757E-01 0.00E+00 0.00 0.00E+00 0.00 5.366E-03 -35.06
Charges on Wire Segments
VALUES OF THE LINE CHARGE DENSITY ON SEGMENTS in As/m
Segment Q
number magn. phase
1 1.32488E-11 -90.69
2 4.30863E-11 -120.06
3 6.83730E-11 -125.06
Currents and Associated Data for Voltage Sources
DATA OF THE VOLTAGE SOURCE NO. 1
real part imag. part magnitude phase
Current in A 1.6718E-02 -9.5781E-03 1.9268E-02 -29.81
Admitt. in A/V 1.6718E-02 -9.5781E-03 1.9268E-02 -29.81
Impedance in Ohm 4.5034E+01 2.5800E+01 5.1901E+01 29.81
Inductance in H 5.4750E-08
