Example 1: Feko Model as Input
Example 1 uses a CADFEKO model (plate4prt.cfx) as input for the Multiport post-processing.
The results between the Feko simulation and the Multiport post-processing application macro calculation are compared.
An application macro is a reference to an automation script, an icon file and associated metadata.
The application macro library allows commonly used application macros to be stored in a repository.
A collection of Lua application macros are available to automate repetitive tasks in CADFEKO.
A collection of Lua application macros are available to automate repetitive tasks in POSTFEKO.
This POSTFEKO application macro can be used to plot all the standard parameters that are available after a characteristic mode analysis simulation was performed.
This application macro is used for calculating mean effective gain (MEG) and envelope correlation coefficient (ECC) for a MIMO antenna configuration. The MEG ratio can also be plotted.
The Multiport post-processing application macro allows you to calculate results for changes in the port loading without rerunning the Solver. Results that are supported are far fields, near fields, currents and specific port parameters, for example, the voltage, current and S-parameters of each port.
The Multiport post-processing application macro calculates the port reflections and field values for changes in port loading, without rerunning the Solver. Through scripting in POSTFEKO, loads can be modified as a post-processing step.
A base multiport Feko simulation is required to generate the required input data for the Multiport post-processing application macro.
The basic workflow of the Multiport post-processing application macro (MultiportPostProcessing.lua) is described.
The Multiport post-processing application macro can be configured to use a Lua settings file to define the loading and excitation for each port. This simplifies the procedure for frequent calculations or large multiport setups with many ports.
The Multiport application macro can be called via the command line through POSTFEKO. Use the --configure-script
argument to pass configuration information to the multiport post-processing script.
The file format and data structure for the output files (.xml and .mat) are described. These files are generated for storing the scaling coefficients for a multiport calculation.
The Multiport post-processing application macro has several limitations.
Use the GenerateMultiportConfigurations.lua application macro in CADFEKO to create the model.
Use the Multiport post-processing application macro in POSTFEKO to calculate the port reflections and field data for a model (plate4prt.fek) with different load configurations.
Example 2 shows how to use stored far field and near field data, in a POSTFEKO session with a multiport S-parameter Touchstone (.snp) file in the Multiport post-processing application macro.
Example 3 shows how to use a Lua settings file to set up the multiport active and non-active port configurations.
The multiport application macro supports calculation from the command-line by calling the application macro via POSTFEKO.
Plot multiport S-parameter results.
An application macro to tile any POSTFEKO views side-by-side.
This application macro uses the S-parameter data from a Feko simulation to display a coupling matrix for a multi-port scenario.
The characteristic mode synthesis and design application macro is a post-processing application macro that can be used to calculate a weighted sum for the currents, near fields, and far fields requests for specific characteristic modes of interest. The application macro uses a modified version of the modal weighting coefficient (MWC) to use the radiating phase when synthesising the results with the macro.
A collection of smaller POSTFEKO application macro are available, but these macros do not include step-by-step instructions.
A collection of Lua macros are available to automate repetitive tasks where the workflow span both CADFEKO and POSTFEKO.
