MIMO Performance Evaluation
This application macro is used for calculating mean effective gain (MEG) and envelope correlation coefficient (ECC) for a MIMO antenna configuration. The MEG ratio can also be plotted.
The application macro is used for calculating mean effective gain (MEG), envelope correlation coefficient (ECC)1. Using the Maths option for the 2D graph, the MEG ratio can also be plotted.
Figure 1. The Evaluate MIMO performance dialog.
Plots of ECC against XPR or MEG against frequency are plotted depending on the selected options.
