Macro Limitations
The farming application macro has limitations on sweep combinations that can be requested for frequency and angle sweeps.
Farm RCS to a PBS Cluster Macro
- The application macro requires a frequency and plane wave source in the model per configuration. The inputs can be global.
- Continuous frequency is not supported.
Combine RCS Sweep Results from Cluster Macro
- The application macro only merges results per sweep configuration.
