Submitting Jobs to the Cluster
Execute the Farm RCS sweep to a PBS cluster application macro in CADFEKO to split a model into smaller runs with one frequency and angle of incidence (phi and theta) to a cluster.
Open CADFEKO and run the Farm RCS
sweep to a PBS cluster macro.
The Farm RCS sweep to cluster dialog is shown.
- Click Browse to select the output directory.
- [Optional] Select the Don't remesh if not needed check box to only mesh the model when required.
- [Optional] Select the Don't save *.cfx/*.cfm files if mesh did not change check box to preserve disk space and only create the files that are required.
Click Submit to start splitting the models and submit
the sweep configuration to the cluster.
Once the model creation has started, a progress dialog is shown.
Complete the process by clicking OK to acknowledge the
messages.
- If the PBS environment is not found, the
PBS job submission failed dialog is shown.
Note: For manual submission, a PBS submission file is created in the output directory.
- The process is finished. The individual models are available in the configuration subfolder in the output directory. A submission file for each sweep configuration is available in the output directory.
Once the models are submitted to the cluster, the following dialog is shown.
