Example for Using the Characteristic Mode Plotter
The characteristic mode analysis plotter application macro is used to plot the various CMA parameters for a simple dipole antenna.
The example model is a half-wavelength wire dipole at 74.9 MHz. The dipole length is 2 m, and it has a wire radius of 2 mm. It is excited by a voltage source at the centre of the wire.
![](../../../../images/feko/lua_scripts/script_characteristic_mode_analysis_plotter/dipole_intro.png)
Figure 1. Simple dipole model.
<FEKO_SHARED_HOME>/installedapplicationmacrolibrary/POSTFEKO/CharacteristicModeAnalysis/CMAPlotter/examples.
