Create a new Cartesian graph. Create two near field traces and
compare the Ey and Ex components of the near field along the X direction.
On the Home tab, in the
Create new display group, click the
Cartesian icon.
Add the near field result to the Cartesian graph.
Add results group, click the
Near field icon. From the drop-down list, select
NearField1.
View the near field along the X direction.
On the result palette, in the Slice
panel, make the following changes:
From the Independent axis (Horizontal) list,
select X position.
From the Frequency list, select
1.645 GHz.
From the Y position list, select
100 mm.
From the Z position list, select
460 mm.
For the purposes of this example, the magnitude of the Ey
component of the field is to be displayed.
On the result palette, in the quantity panel,
clear the X check box and the
Z check box.
Add a second trace to the Cartesian graph by
duplicating the NearField1 trace.
On the Trace tab, in the
Manage group, click the
Duplicate trace icon.
A second trace, NearField1_1, is
created.
For the purposes of this example, the magnitude of the Ex
Ensure NearField1_1 trace is selected on the result palette.
On the result palette, in the quantity panel, select the
X check box and clear the
Y check box.
Over most of the aperture Ex is much smaller than Ey.
It is therefore recommended to set the vertical axis to dB.
Select both traces (NearField1 and
NearField1_1) and on the result palette, in the quantity panel, select the
dB check box.
Modify the minimum and maximum values for the vertical axis.
On the Cartesian
context tab, on the Display tab, on the Axes group, click the
Axis settings icon.
On the Axis settings (Cartesian graph) dialog,
select the Vertical tab.
Clear the Automatically determine the grid range
check box.
In the Maximum value field, enter a value of
40.
In the Minimum value field, enter a value of
-20.
