Matching the Antennas with Optenni Lab
Use Optenni Lab to match the antennas. Use the application macro “Optenni Lab: Port matching”.
Simple examples demonstrating antenna synthesis and analysis.
Simple examples demonstrating antenna placement.
Simple examples demonstrating radar cross section (RCS) calculations of objects.
Simple examples demonstrating electromagnetic compatibility (EMC) analysis and cable coupling.
Simple examples demonstrating using waveguides and microwave circuits.
Simple examples demonstrating phantom and tissue exposure analsysis.
A simple example demonstrating the time analysis of an incident plane wave on an obstacle.
Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO (large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
Use application automation to perform operations with CADFEKO and POSTFEKO. Typical tasks include repetitive tasks, tasks that require several steps, or calculations.
Increase productivity when dealing with predictable and repeatable POSTFEKO sessions (for example, exporting a report) using application automation. Use an automation script to configure a session and export a report that highlights the antenna properties of the model.
Design matching antenna circuits with Optenni Lab and use the circuit in Feko.
This example shows how to use S-parameters with the Optenni Lab: Port matching application macro. The S-parameters was requested with a Multiport S-parameter configuration.
Import the model from the .dxf file. Create surfaces from the imported model outline.
Define the calculation requests in CADFEKO.
Complete the model construction in CADFEKO.
Create the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
Run the computational electromagnetic (CEM) validate tool to perform basic validation on the CADFEKO model.
Run the Solver to compute the calculation requests.
Solve the dual PIFA antenna and obtain the unmatched S-parameters.
This example shows how to use the Optenni Lab: Port matching application macro to transfer far field data to Optenni Lab. The radiation pattern data is then considered when designing matching networks with Optenni Lab.
Design a bandpass coupled line filter with Altair HyperStudy as optimisation engine and Feko as the computational solver.
