Automatic Report Generation Using API
Increase productivity when dealing with predictable and repeatable POSTFEKO sessions (for example, exporting a report) using application automation. Use an automation script to configure a session and export a report that highlights the antenna properties of the model.
![](../../../../images/feko/example_guide/EG_I02_postfeko_application_automation/report_quick.png)
Figure 1. Results of the automatic report generation for two different antenna types.
