Different Ways to Feed a Horn Antenna
Calculate the far field pattern of a pyramidal horn antenna at 1.645 GHz.
![](../../../../images/feko/example_guide/EG_A11_horn_feeding/intro.png)
Figure 1. A 3D view of the pyramidal horn antenna with far field pattern cuts in POSTFEKO.
- Physical feed pin with voltage source.
- Waveguide port with waveguide source.
- Impressed field distribution (aperture source).
- FEM modal port with modal source using the finite element method (FEM).
