Yagi-Uda Antenna Above a Real Ground
Calculate the radiation pattern for a horizontally polarised Yagi-Uda antenna consisting of a dipole, a reflector and three directors at 400 MHz. The antenna is located 3 m above a real ground which is modelled with the Green’s function formulation.
Figure 1. A 3D view of the Yagi-Uda antenna suspended over a real ground with symmetry in CADFEKO.
