Specifying the Area of Simulation
Increase the extent of the computational domain.
View Figure 2 and observe that the default extent of the computational domain (indicated by the red rectangle) does not include the antenna site. Modify the computational domain to include antenna site.
Launch the Edit Project Parameters dialog using one of the
following workflow:
- On the Project menu, click
Edit Project Parameters.
- On the Project toolbar, click the
Edit Project Parameters icon.
- Press F3 to use the keyboard shortcut.
- Click the Simulation tab.
Specify the lower left corner.
- In the x / Longitude field, in the Lower Left Corner column, enter a value of 50.
- In the y / Latitude field, in the Lower Left Corner column, enter a value of 10.
Specify the upper right corner.
- In the x / Longitude field, in the Upper Right Corner column, enter a value of 210.
- In the y / Latitude field, in the Upper Right Corner column, enter a value of 200.
![](../../../../images/winprop/getting_started_guide/example2/dialog_edit_project_parameter_simulation_tab_area_of_planning.png)
Figure 1. The Edit Project Parameters dialog - Simulation tab.
