Specifying the Output Folder for the Prediction Results
Specify the folder for the prediction results to be computed using the dominant path model (DPM).
- Click the Propagation tab.
Specify the output folder for the results to be computed using the dominant path model.
- Under Output Directory / Basic Filename for Propagation Results, in the Directory field, change the default PropName to Prop02_DPM.
![](../../../../images/winprop/getting_started_guide/example2/dialog_edit_project_parameter_propagation_tab.png)
Figure 1. The Edit Project Parameters dialog - Propagation tab.
