Result Palette
The result palette is a panel that gives access to options that control the data in the 3D view or graph.
Collapse the result palette to expand the 3D view. On the View tab, in the Show group, click the  Palette icon.
If different types of results are loaded, then the result palette layout and options update according to the selected data. If multiple results are simultaneously selected, settings common to all the results are available.
