Continuous Frequency (Export Settings)
Choose the frequency stepping and number of samples exported to a .isd or .snp file in a solution with continuous (interpolated) frequency.
![](../../bank/ribbon/../../../../images/feko/icons/button_frequency.png)
![](../../../../images/feko/user_guide/cadfeko/dialog_solution_frequency_export_tab.png)
Figure 1. The Solution frequency dialog (Export tab).
- Specify number of samples for exported data
- This option allows you to specify the number of discrete frequency samples to be extracted from the continuous data when exporting to a .isd file or a .snp file.
- Frequency stepping
- This option allows you to select either a Linear increment or a Logarithmic increment for the extracted discrete frequency samples for export to a .isd file or .snp file.
