Cable Schematic Elements
View the circuit elements that can be added to the cable schematic view.
| Icon | Name | Description |
| Resistor | Add a resistor to the cable schematic view. | |
| Capacitor | Add a capacitor to the cable schematic view. | |
| Inductor | Add an inductor to the cable schematic view. | |
| Complex load | Add a complex load to the cable schematic view. | |
| SPICE circuit | Import a SPICE circuit from a file to define the circuit. | |
| Cable general network | Import an N-port Touchstone from file to define a general network. | |
| VCVS | Add a voltage controlled voltage source (VCVS) to the cable schematic view. | |
| Transformer | Add a transformer to the cable schematic view. | |
| Ground | Add a ground to the cable schematic view. | |
| Cable port | Add a cable port to the cable schematic view. Voltage sources and loads can be applied to cable ports. | |
| Voltage probe | Define a voltage probe to measure the voltage between two points and add to the cable schematic view. | |
| Current probe | Define a current probe to measure the current at a point and add to the cable schematic view. |
