Other CADFEKO Application Macros
A collection of smaller CADFEKO application macros are available, but these macros do not include step-by-step instructions.
Pre-Process PollEx REI File
This application macro imports a .rei file from Altair PollEx and creates the associated geometry in CADFEKO.
Create Rough Sea Surface
This application macro creates a CADFEKO model of a rough sea surface.
Create Inductive Charging Coils
This application macro creates a CADFEKO model of two inductive charging coils.
Ideal Power Divider
This application macro generates a network model of an ideal n-port power divider with unequal division, a 2-port Wilkinson power divider with unequal division, and an n-port Wilkinson power divider with equal division.
Create Far Field Equivalent Sources Split Over Frequency
This application macro creates a far field equivalent source for each frequency split over multiple configurations. The application macro also adds a receiving antenna request with each configuration.
Note: Run the Combine Far Field Equivalent Sources application macro in POSTFEKO to combine the result for each configuration.
Optenni Lab: Port Matching
This application macro uses Optenni Lab to generate matching networks for all desired ports.
Parameter Sweep: Create Models
This application macro generates different permutations of a parametric model based on varying the value of the model variables.
