The example is intended for users with no or little experience with CADFEKO. It makes use of a completed rectangular horn model to familiarise yourself with model creation in CADFEKO and viewing the simulated results in POSTFEKO.
The example is intended for users with no or little experience with CADFEKO. This example is not an example intended for simulation, but rather to familiarise yourself with model creation in
CADFEKO.
The example considers the reflection coefficient and impedance of a microstrip patch antenna on a substrate modelled
on an infinite substrate and then on a finite substrate.
Launch the Solver to calculate the results. No requests were added to this model since impedance and current information are calculated
automatically for all voltage and current sources in the model.
This example showed the construction, configuration and solution of a waveguide power divider. The model consists of a
hollow cuboidal sections with a cylinder (pin) in the centre. The near field and input reflection coefficient was calculated
and displayed.
Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
Translate the model to set symmetry to use model symmetry and reduce computational
costs.
Symmetry planes are only possible at the global origin. Center the geometry across
the X, Y and Z planes.
In the model tree, select Union2.
On the Transform tab, in the
Transform group, click the Translate icon.
On the Translate dialog enter the
From and To coordinates.
To: (0, 0, 0).
Note: This translation will move the structure down so that it is symmetrical
around the XY plane.
Click OK to close the dialog.
The model has magnetic symmetry across the XZ plane and
electric symmetry across the XY plane. The computational resources
can be reduced by allowing the solution kernel to utilise symmetry. Note that this
step is optional and you are encouraged to remove symmetry later to compare the
differences in resources.
On the 3D View
context tab, on the Display options tab, in the
Solver display group, click the Symmetry icon.
Specify the following symmetry:
Y=0 plane: Magnetic
symmetry
Z=0 plane: Electric
symmetry
Optional: Hide the symmetry.
On the 3D View
contextual tabs set, on the Display tab, in the
Method display group, click the Symmetry icon.
