Adding a Near Field Request
Add a near field request to calculate the fields on a surface through the centre of the waveguide.
- On the Request tab, in the Solution requests group, click the Near field icon.
On the Request near fields dialog, enter the values as
indicated.
Dimension Start End No. of Points U -10 30 32 V -20 20 32 N 0 0 1 -
Clear the Sample on edges check box.
Note: A near field request on PEC boundaries will result in a warning by the Solver.
- In the Label field, use the default (NearField1).
- Click Create to add the near field request and to close the dialog.
