Map or add a name to the Webdav drive in your local machine so that the files in the job's running directory on the
HPC complex can be accessed and viewed.
Application definitions are a predefined set of instructions to describe application parameters, store responses and
prepare responses for job execution.
Configure Remote Drive
Map or add a name to the Webdav drive in your local machine so that the files in the job's running directory on the HPC complex can be accessed and viewed.
