Discover new features and enhancements.
Discover Compose, including its language support and system requirements.
The Compose tutorials and associated example model files help introduce you to the basic functionality of the software.
Provides detailed information regarding the features and functionality available in Compose.
Compose 2021.0.1 runs on Windows and Linux 64-bit platforms. Supported platforms include Windows 7/10 and Linux RedHat RHEL 7.4 and SUSE 12SP3.
An overview of the utilities and tools you see when you start Compose.
OML is Compose's math and scripting language.
Compose supports the Tcl scripting language, revision 8.5.9, for editing, execution, and debugging.
Compose supports Python 3.5.4 as a scripting language.
Compose supports R as a scripting language for both edition and execution.
The Compose Integrated Development Environment offers many tools which can be used for authoring and debugging operations.
Use the Editor to create or open script files for authoring and execution.
The Project Browser displays all open files and plots within the current session contents in a hierarchical tree.
Additional folders can be created and nested within the Files folder. These are virtual folders and are not created on disk.
Additional files can be created and added to the Project Browser.
The OML window is used to enter, execute and display the execution of Compose language commands. It also displays print command outputs generated when scripts are executed from the Editor.
The File Browser allows for browsing folder contents, adding new files, and deleting existing ones.
The Command History window displays all the commands entered at the command window by date since the last full erase.
Displays demo files (OML, Python and Tcl scripts) that are present in the installation.
The Variable Browser displays all the workspace variables along with their value, type, and scope.
The displays various information about the currently selected item in the Project Browser.
Plots (either 2D or 3D plots) are created by executing plot commands from either the OML Command Window or inside an OML script. Plots are displayed in a dedicated area located to the right of the Editor area.
A matrix can be accessed from the Variable Browser.
The Bookmarks window lists all the bookmarks in the project. Each bookmark is listed along with its host file and the line number.
Compose contains five menus: File, Edit, Views, Tools, and Debug.
Learn how to open, create and close scripts.
Scripts can be executed by clicking Run.
In Compose, you can create 2-D and 3-D plots using OML plotting commands.
Use the Debugger to find errors in the script.
The Compose Notebook is a web-based implementation of Compose’s OpenMatrix Language (OML) into a Jupyter Notebook. Notebooks (see www.jupyter.org) are a powerful way to execute and demonstrate scripted languages.
Additional libraries can be written in the C/C++ or Fortran language and interfaced with OML.
Reference guides are available for functions and commands supported by OML, Tcl, and Python.
(c) Altair Engineering, Inc. All rights reserved.
