Records Variable Configuration
The Records variable is available in the Record Graph and Table visualizations.
1. To associate columns from the data table, drag and drop them to the Records variable drop area. Select a text column to display the corresponding configuration pane.
The name of the dragged column and its aggregate (e.g., Text Unique) are displayed as the header.
2. You can opt to change the column to the be used as the Record variable from the Column drop-down list.
3. Select the text aggregation method from the Aggregate field: Count Distinct, Text Unique, or Text Concat Distinct.
The default is Text Unique.
4. Enter the label of the Record variable in the Variable Title field.
5. Select the column that will be used as the Color in the Apply Color To field.
6. Sets how the color variable is displayed in the Apply Color To drop-down: Background or Text.
Sample 1: If 1 Day Change % (USD) column is selected and the Apply Color To is set to Background, then the visualization will be:
Sample 2: If Industry column is selected and the Apply Color To is set to Text, then the visualization will be:
7. Click the Icons drop-down and check the boxes of the columns with icons that will be assigned for this particular column.
8. Click the Save
icon on the toolbar.
When
saved, the
notification is displayed.
For numeric records, follow the steps below.
1. Select a numeric column to display the corresponding configuration pane.
2. You can opt to change the column to the be used as the Records variable from the Column drop-down list.
3. Specify an aggregation method in the Aggregate field.
The default is Sum.
The Records variable also supports a number of other aggregate types.
· If you set the aggregation method to Intercept, Slope, Weighted Mean, Weighted Harmonic Mean, Percent of Weight Total, Weighted Sum, Percent of Weight Parent, Percent of Total Change, Cumulative Sum, Cumulative Sum by Max, or Ratio , the Weight Column drop-down list is enabled and displays a list of numeric data columns in the selected data table that can be used as the weight column for the aggregate.
· If you set the aggregation method to Percentile, the Percentile field is displayed. Specify the value that can be used to calculate the value of the selected percentile.
4. The Format field lets you specify the format that numbers will be displayed in. Panopticon uses the same formatting rules as Excel.
5. Select the Divide By value to divide a number:
· 1
· 1000 (by a thousand)
· 10000
· 1000000 (by a million)
· 1000000000 (by a billion)
6. Enter the label of the Record variable in the Variable Title field.
7. Select the column that will be used as the Color in the Apply Color To field.
8. Sets how the color variable is displayed in the Apply Color To drop-down: Background or Text.
9. Click the Icons drop-down and check the boxes of the columns with icons that will be assigned for this particular column.
10. Click the Save
When
saved, the
