Z Variable Configuration
The Z variable is available in the 3D Surface Plot visualization and is used to set the height.
The configuration pane for the Z variable is the same as for the Size variable.
NOTE |
For the 3D Surface Plot visualization, you can set the visible range for the Z variable which can either be calculated dynamically (the default, enabled Dynamic).
Check Always Include Zero box to let the axis scale start at zero, and grow to any number that may show up in the data. Or set between predefined limits by clicking Fixed. This displays the Min and Max text boxes that are populated with the default values taken from the data set.
