Altair® Monarch® Server
Monarch Server System — Installation Procedure
This document describes the installation procedure of the following Monarch Server System products:
q  Automator
q  Content System
q  Report Mining Server (RMS)
The products can be installed on your server together, or each one can be installed separately. Before installing, make sure that the corresponding product is included with the license you obtained.
Note that this install guide provides the steps for installing Monarch Server components in a single server. If you wish to install a distributed setup (i.e., using more than one server), follow the steps detailed in the Monarch Server Advanced Installation Guide instead.
NOTE
Monarch Server Single Server is no longer supported for deployment on non-Windows Server-based platforms.
To view the latest updates in the Monarch Server documentation, visit https://help.altair.com/2021/monarchserver.
2021.0/20220119
