The Altair® Monarch® License Manager
The Altair Monarch License Manager is responsible for licensing a number of Altair Monarch products. The application manages trial mode and activation and deactivation of licenses.
The Monarch License Manager Wizard appears when you launch a newly installed product so that you can configure the appropriate licensing method.
Details of the Monarch Altair License Manager application are displayed when you click the About link located at the upper right-hand corner of the dialog.
You can switch from one type of licensing to another at any time you wish by using the Monarch License Manager. You could, for example, switch from your trial license (without completing the trial period) to using Altair Hosted HyperWorks Units or a volume license key file. To do so, simply launch the Monarch License Manager and select any of the other licensing options available to you.
2020.0.1/2020.07.07
