Altair® Monarch®
Export Design
Export Design allows you to create or edit exports. You go to this mode within Export View.
The Export Design interface has the following elements:
Element
[ 1 ] Ribbon
Display all the tools you need to work with an export definition.
Refer to the Export Design Ribbon Quick Reference.
[ 2 ] Selector
Allows you to search for and/or select a specific export.
[ 3 ] Source Panel
Allows you to view or edit the properties of your source. This panel displays a different set of properties depending on the source you have selected (report, table or summary).
[ 4 ] Output Panel
Allows you to view or edit the properties of your output. This table displays a different set of properties depending on the output type you have selected..
To go to Export Design, select Export Design on the Export View Ribbon.
