Edit Report Colors Dialog
Use this dialog to assign colors to
templates in the Report window.
To access this dialog, select Report
Colors from the Report
Design ribbon.
options
Field |
Description |
Template
Coloring options |
None:
Select if you don't want to apply colors to templates in the
Report window. Note:
Selecting this option will render the templates invisible.
Gray
background: Select to highlight templates in the Report
window with a gray background.
Custom
background for each template type: Select if you want
to create a custom background color for each template type,
then click the adjacent Edit buttons and use the Color dialog
that displays to specify the desired color.
Page
Header: Click the adjacent Edit button to specify
a custom color for the page header template
Append:
Click the adjacent Edit button to specify a custom color
for the append template(s).
Detail:
for the detail template.
Group
Footer: Click the adjacent Edit button to specify
a custom color for the footer template(s).
Show
Greenbar |
Select
to display the reports with the greenbar
feature. |
OK |
Saves the current
settings and closes the dialog. |
Cancel |
Cancels any changes
you have made to the settings and closes the dialog. |
Help |
Displays this
help topic. |
