Altair® Monarch®
Editing/Revising Templates
When you accept a template, data is extracted from the spreadsheet and displayed on the Prepare Window:
You can work with the data at this point as you would with any table. However, you can still modify how the data is extracted by editing the templates.
Steps
  1. Right-click on the table.
  2. Select Edit in Worksheet Design from the context menu.
  3.
  4. Edit the traps as needed.
