TSTEPNX
Bulk Data Entry Defines additional parameters for geometric nonlinear implicit dynamic analysis.
| TSTEPNX | ID | TA0 | DTA | DTTH | NPRINT | RFILE | |||
| SOLV | TSCTRL | DTMIN | DTMAX | LSMETH | RREFIF | NCYCLE | FIXTID/TOUT | ||
| DYNA | ALFA | BETA | GAMA | SMDISP | |||||
| ITW | DTSCI | LDTN | DTSCD | LARC |
Example 1
| TSTEPNL | 99 | 0.01 |
Example 2
| TSTEPNL | 99 | 0.01 | |||||||
| TSTEPNX | 99 | 0.1 | |||||||
| NEWT | ARC | 1.e-4 | 0.1 |
Example 3
| TSTEPNL | 99 | 0.01 | 3 | PW | |||||
| 0.01 | 0.01 | ||||||||
| NEWT | ARC | 1.e-4 | 0.1 | ||||||
| NEWM | 0.25 | 0.5 |
| ID | An associated
TSTEPNL entry identification number. No default (Integer > 0) |
| TA0 | Start time for writing
animation files. Default = 0.0 (Real ≥ 0) |
| DTA | Output time step for
animation files. If zero, no output. 3 Default = DT (Real ≥ 0) |
| DTTH | Output time step for time
history files. If zero, no output. 3 Default = 0.1*DT (Real ≥ 0) |
| NPRINT | Print every
NPRINT iterations. If negative, to
.out and standard output; if positive, only
to .out file. Default = -1 (Integer) |
| RFILE | Cycle frequency to write
restart file for nonlinear iteration. Default = 5000 (Integer > 0) |
| SOLV | Geometric nonlinear
implicit solution method
(Character) |
| TSCTRL | Time step control.
(Character) |
| DTMIN | Minimum geometric
nonlinear implicit time step. If DTMIN is
reached, simulation will be terminated. 3 Default = 1e-5*DT (Real ≥ 0) |
| DTMAX | Maximum geometric
nonlinear implicit time step from which time step is set constant.
3 Default = 3*DT (Real > 0) |
| LSMETH | Line search method.
(Character) |
| RREFIF | Special residual force
computation with contact interfaces present.
Default = no special treatment (Integer) |
| NCYCLE | Maximum number of time
steps. If reached, solution will be terminated,
NCYCLE=0 means no
limit. Default = no limit (Integer ≥ 0) |
| FIXTID | A
TABLEDi entry identification number. The x
values of the table define fixed time points that the automatic time
step control will adhere to. (Integer > 0) |
| TOUT | The method to determine
the fixed time point.
| DYNA | Implicit transient
solution methods.
(Character) |
| ALFA | Parameter in α-HHT Method
(DYNA = HHT). Default = -0.05 (Real, -1/3 < ALFA < 0.0) |
| BETA | Parameter in general
Newmark method
(DYNA=NEWM). Default = 0.25 (Real, -2 * BETA ≤ GAMA < 0.5) |
| GAMA | Parameter in general
Newmark method
(DYNA=NEWM). Default = 0.5 (Real, -2 * BETA ≤ GAMA ≤ 0.5) |
| SMDISP | Perform small displacement
and rotation analysis instead of geometric nonlinear analysis. PARAM, SMDISP,
YES overwrites this definition.
| ITW | If the solution of a time
step converges within ITW iterations, the next
time step will be increased by a factor controlled by
DTSCI. Default = 6 for TSCTRL=ARC Default = 2 for TSCTRL=SIMP (Integer > 0) |
| DTSCI | Maximum scale factor for
increasing the time step
(TSCTRL=ARC). Scale factor
for TSCTRL=SIMP. Default = 1.1 (Real > 0) |
| LDTN | Maximum number of
iterations before resetting and decreasing the time step by a factor
of DTSCD. Default = 20 for TSCTRL=ARC Default = 15 for TSCTRL=SIMP (Integer > 0) |
| DTSCD | Scale factor for
(TSCTRL=ARC or
SIMP). Default = 0.67 (Real > 0) |
| LARC | Input arc-length for
TSCTRL=ARC. Default = automatic computation (Real) |
- The TSTEPNX Bulk Data Entry is selected by the Subcase Information command TSTEP=option. There must also be a TSTEPNL Bulk Data Entry with the same ID. It is only used in geometric nonlinear implicit dynamic analysis (ANALYSIS=IMPDYN); it is ignored in other analyses.
- The solution method for geometric nonlinear implicit analysis is selected by SOLV. The frequency of stiffness matrix updates is controlled by TSTEPNL, KSTEP. For highly nonlinear problems, it is recommended to reduce KSTEP for better performance. KSTEP=1 means full Newton.
- The initial time step DTINI=DT is defined by TSTEPNL.
- For more information about geometric nonlinear analysis, refer to Explicit Dynamic Analysis (Radioss Integration) in the Users Guide.
- This card is represented as a loadcollector in HyperMesh.
