OS-E: 0500 Restart of NLSTAT
Demonstrates Restart Nonlinear Static Analysis followed by Complex Eigen solution using STATSUB (BRAKE).
Figure 1. FE-Model
Model Description
The objective is to restart the Nonlinear Static Analysis followed by a Complex Eigen Analysis. For more details about this FEA model, refer to OS-T: 1371 Brake Squeal Analysis of Brake Assembly.
Results
The Brake Squeal Modes with and without restart are very close at 1950.2 Hz frequency, as shown in Figure 2.
Figure 2. Unstable Modes from the Complex Eigen Solution
Model Files
The model files used in this example include:
<install_directory>/hwsolvers/demos/optistruct/examples/BRSQ_WRITE_v17.fem
<install_directory>/hwsolvers/demos/optistruct/examples/BRSQ_READ_17.fem
