Exercise 2: Nonlinear Gap Analysis
Create a Load Collector Defining Parameters
Update the Load Steps
Submit the Job
- rib_nonlinear.html
- HTML report of the analysis, providing a summary of the problem formulation and the analysis results.
- rib_nonlinear.out
- OptiStruct output file containing specific information on the file setup, the setup of your optimization problem, estimates for the amount of RAM and disk space required for the run, information for each of the optimization iterations, and compute time information. Review this file for warnings and errors.
- rib_nonlinear.h3d
- HyperView binary results file.
- rib_nonlinear.res
- HyperMesh binary results file.
- rib_nonlinear.stat
- Summary, providing CPU information for each step during analysis process.
and hide all components except the Web component.
to display a top view
of the Web.
to end the
