Altair HyperLife 2021 Release Notes
New Features
Batch Run Submission
The Batch submission tool is enabled using the Batch icon within the Utilities group. The Batch submission tool invokes the Batch Run dialog where the XML input file is uploaded. This will facilitate running HyperLife jobs at a later time with an input file created in the Evaluate tool.
Export XML file
The run setup in HyperLife can be exported as a XML file, which can be used at a later time for Batch Run Submission. The XML file contains all the settings (approach, type, mean stress correction option, material assigned, and load mapping) to execute a Fatigue run in HyperLife. The XML file can be text edited for user manipulation. Use the Export button in the Evaluate tool to write the XML into the working directory. The created XML file will have the file prefix as the run name with a *.xlm file extension.
Log file
A log file (*.log) is created after the run is executed in the working directory. The log file will contain the following information: analysis type, events created, materials assigned to part/set, and evaluation time.
MORROW damage model for EN Multiaxial
MORROW tension damage model (mean stress correction option) for Strain Life (EN) Multiaxial analysis is available. The selection options are dynamically updated in the EN tool when Multiaxial type is selected.
Scale and Offset option in MATERIAL tool
The Scale and Offset options are available for the stress history scaling in the Material tool. With the SN and EN approaches, users can now enter Scale and Offset values for individual components/sets, which applies to the specific type of material assigned. The Scale and Offset options are also present in the Load Map tool which applies to all the components selected for analysis.
Tool tip in Load Map tool
Tool tips are available in the Load Map tool. The tool tip will highlight the Channel and Subcase/Loadcase name from the Input file in the event window.
Enhancements
Input number of critical planes
The number of critical planes is available as a user input option. This is supported for both Uniaxial and Multi axial methods (shell models only).
Enhanced FKM mean stress correction option
When the FKM mean stress correction option is selected for Stress Life (SN) with Uniaxial and Multiaxial method, additional user input options are available in the Material tool. The FKM Mean Stress Sensitivity (MSS) value can be input separately for the four regions in the Haigh diagram (based on FKM recommendation).
Performance improvement with Vibration Fatigue Analysis
With Vibration Fatigue Analysis, analysis time is improved when subsequent runs are performed in the same session.
Resolved Issues
  • User defined sets not retained in *.hlf file is resolved.
  • Rainflow matrix showing wrong number of cycles for Random Fatigue Analysis is resolved.
Known Issues
  • When single column Load history files (CSV format) are loaded in the Load Map tool, there is a known issue with application error. The work around is to modify the CSV file inserting a pseudo first column.
  • There is a known issue with Auto and Cross correlation terms with Vibration Fatigue. While creating an Event in the Load Map tool with Vibration Fatigue loading type, HyperLife automatically creates Auto correlation and Cross correlation pair/terms for all the selected subcases/loadcases. There is a known issue when any combination of terms of no interest are manually deleted; the wrong results will be output. The user is advised to retain all the terms/pairs which are of no interest without assigning any PSD channel. These unassigned/blank terms (without any PSD channels) are excluded from the calculation.
Altair HyperLife Weld Certification 2021 Release Notes
New Features
Weld Fatigue Assessment with Solid Elements
Weld Fatigue assessment with Solid Elements (3D idealization) is supported for DVS1612, FKM, and Eurocode 3 norms. The tool automatically generates a surface skin layer for stress recovery. Weld lines are detected and classified within the weld browser with the standard workflow which is common for both shell and solid models.
Evaluation at Weld Ends
The tool now automatically identifies the weld ends and an additional evaluation location is assigned. This feature is enabled and exposed for user control in File > Preferences > HyperLife Weld > Enable Weld End.
Export Result Table
The assessment results can now be exported to a spreadsheet (CSV file format). The Export Result Table button in the Result Explorer page will write a CSV file into the working directory.
Static assessment of Welds
Static assessment of Welds is supported for DVS1612, FKM, and Eurocode-3 norms for shell models. Results are output by default under Contour Results on the Result Explorer.
Enhancements
Weld Property File import in Points tool
The import option for Weld Property File has moved to the Points tool. This import option was present in the Specification tool in earlier releases.
Ratio contour for Shell elements on Inspect Browser
Ratio contour of the down selected welds is available in the Inspect browser within the Inspect tool.
Min and Max Stress contour for Unwelded Evaluation
The Min and Max Stress result contour is available for Unwelded Evaluation under Contour Results in the Result Explorer.
Activate/deactivate Effective Weld Thickness in Preferences
An enhanced Preferences options to activate and deactivate Effective Weld Thickness is available under File > Preferences > HyperLife Weld.
Target cycles input option removed from Points tool
The Required Number of Cycles input option has been removed from the Points tool. Modify the desired repeats in the Evaluate tool.
Resolved Issues
  • Stress Query for skewed elements is resolved. Jacobian threshold can be tweaked in Preferences.
  • Reloading a session file issue is fixed. When intending to reload a session file, only load the *.hm file created by HyperLife Weld Certification in the working directory. Solver result files are not required while reloading a session file which will reset the run settings.
