Network View
The network view is a block diagram view emphasizing inter-connectivity of the assembly.
It is one of the three views in the assembly environment, along with the graphics view and the browser view. The network view is the best way to show coincident connections and provides an easy way for checking the number of connections between any two modules, reducing modeling errors.
Click the Network View tool.
Entities in the Network View
Boxes represent modules or subsystems in an assembly. A typical module has a number of tagpoints represented by small circles on the border of the boxes.
Ellipses represent connections between tagpoints on modules joined by two lines emanating from each ellipse. The arrow that appears on one end of the lines indicates that the module pointed to by the arrow is the owning module of the connection.
Figure 3.
Organizing the Network View of an Existing Assembly
When invoking the network view for the first time, an auto generated block diagram is displayed, which is not likely satisfying. After some effort in organizing the modules and connections, the block diagram can be organized in an easy to view form. The organized view can then be saved in the assembly .xml file so that the organized view will be available when the .xml file is imported.
Recommended steps in organizing the network view
  1. Turn off the visibility connections by unchecking the Visibility checkbox.
  2. Click the icon to increase the horizontal box size so that the module names are mostly inside of the boxes. Make sure that the entity resize toggle is turned on.
    Figure 4.
  3. Make the body box wider. Block the select half of the modules by dragging the left mouse cursor and then move the selected modules up to make room. Click the body's left and right edge and then drag to enlarge the horizontal size.
  4. Arrange the modules connected to the body above and below the box first and then sequentially arrange the remaining modules based on their connectivity.
  5. Re-check the Visibility checkbox to turn on the connectors.
  6. Click the icon to reset the connection locations to Auto Generated Positions.
  7. Rearrange and expand the collapsed connections until the view is satisfactory.
Entity Sizing Control
Module and connections can be selected to be moved by left-clicking the object. To move a tagpoint, left-click the small circle while holding down Ctrl.
When moving modules, attached connections can be set to either move with the modules by clicking the icon to on, or stay at their current positions by clicking the icon to off. When moving either modules or connections, connection lines can be set to maintain a perpendicular relationship to module boxes by clicking the icon to on.
Interrogating Module and Connection Definitions
Double-clicking any module box or connection ellipse opens the module/connection manager to see the respective item’s definition.
Figure 5.
Figure 6.
This option shows the ID range for modules.
Figure 7.
There is an option available with the context menu on connection to change the owning module of a connection.
Figure 8.
Create/Delete Modules and Connections
Modules can be created or deleted by using the context menu.
At this point, connection creation/deletion can only be done from the connection creation GUI and the Connector browser. The alignment of both module and connection can be accomplished from the same context menu.
Pan/Zoom/Fit All
Panning can be done by clicking Ctrl and the middle mouse button, or by clicking the arrow in the toolbar.
Figure 9.
Dynamic zoom
Can be done by clicking Ctrl and scrolling the middle mouse button.
Window zoom
Can be done by clicking Ctrl and drawing a window while holding the middle mouse button.
Fixed zoom
Can be done using the icons shown below.
Figure 10.
Fit All can be done by clicking the icon.
Coloring Capabilities
Coloring capabilities assist you in quick diagnostic related to missing representations for a module, connection types and realization.
Figure 11.
Figure 12.
Figure 13.
Figure 14. A Module with a Solid Red Outline Represents a Module not Assigned with a Representation File
Figure 15. A Module with a Solid Black Outline Represents a Module Assigned with a Representation File
Figure 16. A Module with a Solid Black Outline and Gray Inside Represents a Module outside the Subsystem Selected for Analysis
Figure 17. A Module with a Solid Black Outline and Green inside Represents a Module Part of the Rolled-up Parent Module and Set for Analysis
Figure 18. A Connection with a Dotted Blue Outline and Dark Green inside Represents a Realized Connection with PBUSH Type
Figure 19. A Connection with a Solid Red Outline and Dark Green inside Represents a Realized Connection with Rigid Type
Figure 20. A Connection with a Solid Black Outline and Red inside Represents a Failed Connection for Realization
Figure 21. A Connection with a Solid Black outline and Gray inside Represents a Connection outside the Subsystem Selected for Analysis and not Selected for Realization
Figure 22. A Connection with a Solid Black outline and Light Green inside Represents a Connection Between the Child Modules of the Rolled-up Parent Module and set for Analysis
Control Volume
Highlights the modules belonging to a particular control volume and connections inside and on boundary of control volume.
Figure 23.
Not in Analysis
Highlights the modules that are not defined for a particular analysis.
Figure 24.
Template CSV Support for Import/Export
Provides the capability to export/import the Network View using a template .csv file using the context menu.
Figure 25.
Connection Realize/Unrealize
Provides the capability to realize/unrealize connection by selecting connections from the Network View using the context menu.
Figure 26.
Mass of Modules and Connections
Provides the capability to review the mass of modules and connections from the Network View using the context menu.
Figure 27.
Prepare Modules
Provides the capability to prepare modules from the Network View using the context menu.
Figure 28.
