Radiated Sound - Load
Load an H3D or PCH results file and plot a response for the Equivalent Radiated Power, Sound Power, or Sound Pressure result types.
Plot a Response for Radiated Sound
  1. From the Radiated Sound Load tab, load the result file to view and load the model.
  2. Make a selection from the Subcase drop-down menu.
  3. Select a Result type from the drop-down menu: Equivalent Radiated Power, Sound Power, or Sound Pressure.
  4. If you select Equivalent Radiated Power:
    1. From the Result component drop-down menu, select a panel.
    2. Click Load Response to plot the response:
      • Linear/dB (Magnitude)
      • Linear/Octaves (Frequency)
      The utility automatically switches to the Display tab.
  5. If you select Sound Power for the result type:
    1. For Result set, select Source Side or Receiver Side.
    2. Click Load Response to plot the response.
  6. If you select Sound Pressure for the result type:
    1. For Result set, select Sound Pressure or Power from Pressure.
    2. For Receiving Panels, select a set that corresponds to particular source nodes. This can be used for panel participation.
    3. For Result component, select the microphone location:
      • Select a node from list
      • Select the microphone location from model
    4. Click Load Response to plot the response.
