Manufacturing Solutions
Workpiece Material Properties
The Workpiece material is used to describe the extrudate in metal extrusion. Typically, this material is applied to the components in the mesh that describe the negative volume created by the tool (such as, billet, pockets, feeder cavity, bearing cavity, welding chamber, porthole etc.). Inside the user profile, we assign this material even to the boundary faces of the workpiece components.  HyperXtrude supports the following constitutive models for metals:
Inverse Sine Hyperbolic model
Metal Forming Power Law model
Norton-Hoff model
Hensel Spittel model
Workpiece Material Properties Data Types
The following table contains descriptions of data types for Workpiece material properties:
Variable Name
Value Type
Remarks
ConstitutiveModel
String in quotes
"SineHypInv"  "PowerLaw"  "TemDependentNortonHoff"
Density
Real (Constant)
Density of the fluid
SpecificHeat
Real  (Constant/Function of Temp.)
Function can be a TABLE1 or EXPRESSION
Conductivity
CoeffOfThermalExpansion
Real (Constant)
Thermal expansion coefficient
VolumetircHeatSource
Real (Constant)
Value per unit volume.
SolidusTemperature LiqidusTemperature
Real (Constant) Real (Constant)
Friction coefficient decreases from its full value at SolidusTemperature to zero at LiqidusTemperature
Temperature Dependence
String in quotes
"None"
"Coefficients"
"Exp(Q/RT)"
"Exp(-Beta(DeltaT))"
"Exp(A1T+A2T^2)"
Amplitude  ConstantY
Only for PowerLaw with "Coefficients" for Temperature Dependence
Other Data
Real (Constant)
Data specific to different material models is described in the following sections.
